Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 08-24-2005, 11:54 PM
hondajohn hondajohn is offline
Send a message via AIM to hondajohn
B16A runs rich, hard to start - HELP!
91 CRX / B16A
Z-dyne ecu
AEM intake
Integra LS tranny
No error codes
Problem: Engine is hard to start and runs rich. It used to start fine cold, but now has the problem when it's cold or hot. It cranks for quite awhile, then finally starts but runs rough (rich) for a few seconds while it clears out, then smooths out. But it still runs rich (exhaust smells rich big time) until it's really warmed up. If it's hot, and I shut it off, then re-start it within a couple minutes, it starts ok, but if it sits, then it's hard to start.
I have checked and re-checked the fuel pressure, vacuum lines, wire connections, etc. I finally just started randomly unplugging sensors and trying to start to see if this made a difference, even though there are no error codes. Nothing has helped yet. Had fuel injectors cleaned not long ago, so don't think that is it. Any suggestions? I think this problem is actually getting worse...
Old 08-25-2005, 03:42 AM
QUICK_EG_B16A QUICK_EG_B16A is offline
Check the o2 sensor and then the cat. converter. when i first had my swap done i had similar problems, replaced both of those and i was golden getting it smogged.
For sale or trade:
1992 Honda Civic CX Hatch
jdm B16A B.A.R. APPROVED
too much to list.
PM is the key!
Old 08-26-2005, 05:45 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: B16A runs rich, hard to start - HELP!
what are you using the z-dyne for?
if your just using it for the current mods you have listed, lose it and throw in a pr3 ecu.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-26-2005, 03:34 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
when you first start your car cold, the motor always runs rich till it warms up, thats how it is.
Team Lonely Drivers
Old 08-27-2005, 12:41 AM
The Z-dyne was what came with the motor. I actually am getting a stock PR3 ecu from someone on this site. I am hoping that will help cure the problem... I have no idea what chip is in this z-dyne.
I think I will replace the O2 sensors even though there are no error codes. They are expensive though! Any idea where to get cheaper aftermarket ones??
Old 09-03-2005, 12:23 AM
hard starting B16
Switched out to the stock PR3 Ecu... it now idles a little bit better than with the Z-dyne, but still no error codes and still very hard starting. It is actually flooding out and I have no idea why... but now I know it has nothing to do with the ECU.
Old 09-03-2005, 12:28 AM
AF - Advisor
check for spark. if that looks good, check your injectors and wiring. if thats fine. swap out a different known working ecu.
