Old 08-24-2005, 10:55 PM
si-willie si-willie is offline
help take off a part
need some help about how to take off my back light the middle part where it say civic
Old 08-24-2005, 11:10 PM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
in the hatch area there is like 5-8 little nuts to take off that go onto the studs on the lights, they are 8mm I think but don't quote me on that..lol. For the center one you may have to take off the interior trim peice if it's in the way of the bolts. Can't say for sure because I've only done crxs, but in the crx there is a little pop off panel that lets you get to change the bulbs and reach the nuts, hope this helps.
Old 08-25-2005, 08:09 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: help take off a part
You are correct the Civic is similar. The only difference is a clip in the center, you should remove the interior panel to access the clip and then you should be able to release the clip with pliers. GL
Old 08-25-2005, 10:15 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i know in the crx there is also a bolt towards the middle of the panel which is hard to see, if you cant remove the piece easily then you still have a bolt attached somewhere, dont try to force it off or you'll snap the panel.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-26-2005, 05:26 PM
skotman's Avatar
skotman skotman is offline
they're 8mm. puny things. same size on the valve cover.
Old 08-26-2005, 08:25 PM
i know - i took all of the puny off and there some thing in the middle of the light where it as CIVIC - like a pice of plasic the its not a light its like a cover. i dont know how it comes off
Old 08-26-2005, 09:01 PM
johnb16a2's Avatar
You have to remove the interior plastic panel on the hatch. In the space between the inner and outer metal panels is the other side of the plastic clip holding the middle of the taillight assembly that says Civic. Get some pliars and pinch the clip, this will release the clip and the part will come off. GL
