Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 08-24-2005, 10:34 PM
Andyjk1 Andyjk1 is offline
71 Skylark not starting
I just bought a 1971 Skylark dirt cheap. It seems like a pretty good project. The motor looks like it has a new water pump, altenator, I put new plugs in and the cap and rotor are in good shape. The engine turns over and sounds like it's firing a bit, but doesn't get that one really good fire where it starts. It's almost hesitating and it appears it puffs back through the carb. I checked top dead center and even pulled off the valve cover and watched the valves to make sure that I was about in the right place with the spark plugs on the distributor cap. I played with the timing adjusting the distributor back and forth a bit and nothing made a difference. In looking down the carb and pumping the throttle, there appears to be plenty of gas spraying down there. Does this sound like the timing chain may have skipped a gear?
Old 08-30-2005, 02:40 PM
Mark30 Mark30 is offline
Re: 71 Skylark not starting
Id say mabee check your compression and firing order
