Old 08-24-2005, 10:06 PM
phatmatt2g3 phatmatt2g3 is offline
97 blazer cold start problem
I have a 97 s-10 blazer, and it has trouble starting in the morning. Once it warms up, it starts back up immediately. Also if you put a little gas on the throttle body it starts right up. I know its not the starter and its not the fuel pump. Any ideas?
Old 08-25-2005, 06:18 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
I'm guessing a fuel pressure leak.
Try leaving the key in the "on" position for 5 - 10 seconds before cranking the engine. This will allow the pressure to build up if you have a leak somewhere in the fuel lines.
Old 08-25-2005, 12:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 blazer cold start problem
Fuel filter
Spark plugs AC Delco Platinum only
Cap & Rotor
Air Filter
PCV Valve
1995 Factory Blazer Service Manual for sale, PM if interested.
