Old 08-24-2005, 10:05 PM
MASman1313 MASman1313 is offline
leaking fluid, Head gasket??
i just bought a 95 eclipse rs and it leaks a mix of oil and water. i heard that it could be the head gasket. What do you think and how much does somethin like that normally go for to get it fixed? i would really appreciate some help!!!!
Old 08-24-2005, 10:10 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: leaking fluid, Head gasket??
Are you sure it's not just leaking both coolant and oil? It could just leak both and they are mixing. Check the oil for coolant and the coolant for oil. It will cost a lot to get fixed at a shop (probably $1000+)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
