Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-24-2005, 10:59 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
turbo...trim...?
I have a stock T-25 turbo and I recently discovered that it has 50 trim installed. Now my question...the "trim" refers to the compressor wheel right? Stock the t-25s are 45 trim? What are the pros and cons of bigger trim? Thank you for the help.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-25-2005, 12:37 AM
i1nk83 i1nk83 is offline
Send a message via AIM to i1nk83
i dont think that you have any idea what you are talking about trim wise. the "50"trim is a t04a,b,c,e,etc . you have a t25 there is no way to stuff a 50trim wheel in there. a t28 wheel maybe but not a 50trim. do some research on turbos, because a 50trim turbo is at least 4x bigger than what you have.
1990 mitsu eclipse gsx
16g
550's
burned eprom chip
2g mas
3" turbo back custom exhaust
port&polished head, turbo, exhaust mani
mml headgasket
b.s. elimination
centerforce df2
unorthodox crank pulley
autometer boost , a/f
hallman es mbc
homemade fmic and piping
relocated battery lower in engine compartment
purty candy red valve cover
stripped interior
couple of random guages
man this is a big list of nothing special......gotta work on that
50trim in the works
Old 08-25-2005, 07:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: turbo...trim...?
Trim says nothing about the turbos size, but rather the inducer to exducer ratio You can have a turbo the size of a quarter and a turbo the size of your head both have a "50 trim" wheel.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-26-2005, 04:36 AM
Whathits14 Whathits14 is offline
When does your turbo spool? But you don't have a 50 trim in a t25.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 08-26-2005, 06:13 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Dyno it and prove it. If u lag alot then its probably a t-28 wheel but i doubt its a 50 trim. Have u seen a 50 trim wheel yet?
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 08-27-2005, 06:42 AM
AF - Advisor
I think everyone missed the part where I said the T25 wheel could be a 50 trim wheel, even if its not THE "50 trim" wheel. The trim is not related to the size of the wheel.
Kevin Jewer
Old 08-28-2005, 04:38 PM
3of9 3of9 is offline
pictures would help ALOT in this thread. i also need help understanding this too. Who ever has time, please show us what the difference is. thanks!
I am not afraid to race you, I'm just waiting my turn...
3of9
Old 08-28-2005, 09:05 PM
NateS's Avatar
Well I'm sorry I'm still new to turbos and such. The guy that owned the car before me didn't help me much either. I'm assuming it's the stock turbo. The only thing I can tell from looking at it is that it is a Garrett turbo. The guy told me it has 50 trim installed but that is all he told me. It starts to spool around 3500 and full boost is around 4500 or so. It seems to spool pretty damn fast compared to other turbo cars I have ridden in. Thank you for any help.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-28-2005, 09:09 PM
NateS's Avatar
Oh and the lag is very minimal. Even with the stock blow off valve. It maybe drops 3-4 pounds then climbs back to full boost fast. If it would help I could get some pictures. I'm sorry I can't provide more information. I know that the turbo was replaced when the tranny/engine was rebuilt but he didn't know if the guy before him put an aftermarket or stock back in it. If thats confusing I'll simplify it for everyone...there were 2 previous owners before me. First guy did all the modifications so the guy I bought it from doesn't know jack shit.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-28-2005, 11:01 PM
NateS's Avatar
Okay I got ahold of the previous owner and he told me that it is deffinatly not a t-25. It is a Garrett model turbo though, obviously (it says it on it the damn thing). Other than knowing it is not a t-25 and that the turbo has 50 trim he said he is clueless to anything else.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-29-2005, 02:52 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
isn't the t25 a garret turbo just a small one?
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 08-29-2005, 02:53 AM
AF - Advisor
The t25 is a garret, but full boost around 4k rpm would be characteristic of a to4e 50 trim. What is the manifold? A full garret turbo will not bolt up to the stock manifold and O2 housing. I'd be a little nervous if the previous owner can't say for sure what turbo is on there. T28 would bolt up. Got any pics?
Kevin Jewer
Old 08-29-2005, 08:45 PM
NateS's Avatar
I don't have pics yet. As for the manifold I'm pretty sure it's stock. The cover for the manifold was taken off and it is rusty as shit so I'm assuming it would be the stock one. I was wondering would an evolution manifold work with a to4e turbo?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-30-2005, 08:27 AM
AF - Advisor
If it is a "bolt on" "hybrid" to4e type turbo, then you can use the EVO3 or SBR manifolds. If its a full garret to4e you need a t3 manifold, like the SFP or turblonetics unit for example.
Kevin Jewer
Old 08-31-2005, 09:56 PM
NateS's Avatar
Got pictures
Okay I finally got pictures. I hope these will help.
Here are the links because I could not get them to upload to this server.
http://nathan21224.tripod.com/pics/Turbo1.bmp
http://nathan21224.tripod.com/pics/Turbo2.jpg
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
