Old 08-24-2005, 06:26 PM
HondaCivic4358's Avatar
HondaCivic4358 HondaCivic4358 is offline
Send a message via AIM to HondaCivic4358
Sunroof only opens once in a while.
What the hell is going on? its been doing this since i bought it. i try to open it and it goes up but never back. i close and open it like 100 times (no joke) and it finally will go back. could my motor be going bad? or is it getting caught on something? ive put wd40 on the tracks, which didnt seem to help at all....
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-24-2005, 08:58 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Sunroof only opens once in a while.
Motor is probably going out. Could get a bad relay also.
Old 08-24-2005, 09:30 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the tracks may have warped slightly, see if the window is coming back evenly at both sides.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-25-2005, 07:46 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
In the back behind the tracks, there is a little notch-like mechanism that must recess into place in order for the sunroof to close completely. If you're trying to open it and it gets stuck, it could be like crxlvr said and have warped tracks. The motor itself is a pretty simple device. I believe you can actually take a screw driver and manually turn the motor to open it fully if you really wanted to. Anyway, it's all hazy to me now because I totally removed my complete sunroof assembly and customized a basic roof in it's place...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-25-2005, 08:47 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
(assuming it's a CRX) chances are the rails are dirty and gummed up with crap.
I just replaced my Rusted out Moonroof on tuesday with a Un-rusted panel. since my original panel had not beed used in over a year, it was a little stiff opening.
If you drop the head liner there is a Nut you can turn to Open and close the Panel manualy. once you get it open, clean and Lube them rails, use WD-40 to clean em but use somethign else to lube em, like teflon grease. then with the motor work it in, back and forth. now if it does not move at all... replace the motor.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 08-26-2005, 09:28 PM
Re: Re: Sunroof only opens once in a while.
so how to you reccomend trying to clean these rails?
1989 Honda CRX Si
D16Z6
2.5 in Exhaust
CAI
Chikara Header
Old 08-28-2005, 06:37 AM
Canabalooza Canabalooza is offline
Mine wouldn’t open at all for a while so I took apart the switch and found out it was all gummed up inside the switch so I cleaned it up and it worked great. Recently it would only shut sometimes I had to keep hitting the button took apart the switch same thing. The grease that they used in the switch dries in the heat and gums everything up. the switch controlls both the up and down and the forward and back if the one part is gummed up and not contacting that could be the problem just like mine. hope that helps.
