Old 08-24-2005, 04:29 PM
XXKoopXX XXKoopXX is offline
Code 20 on ECU
I'm getting 20 Flashes on my ECU and my car will not start. I converted this 90 Civic Hatch from Automatic to Manual.
I had the starter and solenoid rebuilt today and that fixed the code 19 I was getting earlier.
What could be the problem here?
Old 08-24-2005, 06:15 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Code 20 (20 flashes) Electric Load
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 08-24-2005, 06:17 PM
I should have specified that I already knew that. Sorry.
Just wondering if someone could give specifics on the problem/problems.
Old 08-24-2005, 06:26 PM
Not to long ago there was another guy on here with that same code.
I never ended up hearing if he got it fixed tho.
Hopefully he'll read this thread and be able to help you out.
||JEFF| |
Old 08-24-2005, 06:47 PM
I just tried manually starting the car using the battery on to the starter solenoid. It starts up and runs no problem. Obviously something must be wrong with my ignition.
When we switched the pedals on the car there was a sensor on the clutch pedal. Could that be causing my car to not start? Am I going to have to run a wire from the pedal to the ECU?
Old 08-25-2005, 07:52 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Code 20 on ECU
It makes sense, since you have to use the clutch to start the car. Maybe somebody with a remote start who has bypassed this "sensor" can help you out. I know Vladlos did it.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
