Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-24-2005, 04:24 PM
ocean0715 ocean0715 is offline
Low Rumble @ 45 MPH plus
Caprice Classic
Old 08-24-2005, 04:31 PM
Re: Low Rumble @ 45 MPH plus
My 93 Caprice Classic 5.0 L runs great smooth etc.
However, at 45 mph plus if I accelerate SLIGHTLY the engine rumbles/ shutters breifly say for about 2-5 seconds or until I get to 50 mph and then stops. It does it again at 65 to 70 when I apply just a little push to the gas. If I give it a lot of gas it doesn't seem to do it. When I back off the gas and slow down 5-10 mph and then apply the gas just slightly it does it again. Once the rumble/shuttering stops the car runs smooth. I suppose it is more of an anoyance than a problem but it runs so smooth otherwise. I think perhaps the fuel filter needs replacing or the stop valve in the trans. is stuck.
Anyone with a suggestion please pass it on.
Old 08-24-2005, 08:16 PM
CD Smalley CD Smalley is offline
Sounds to me like your torque convertor lockup has failed or is failing. Try tapping brake pedal next time it does this and see if it stops for just a second or two...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-08-2005, 01:56 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I agree with the converter lockup diagnosis. Go under the car and unplug it at the transmission, it should be on the driver side towards the front. Go for a ride, if all is well, you found the problem.
Bob
