Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 08-24-2005, 03:26 PM
silvertip silvertip is offline
Sunfire/Cavalier Stereo
Not sure if this has been posted yet or not but here is what I have found when installing a new stereo.
As the late model Sunfire/Cavalier do not have the accessory wire in the dash for a new stereo install, I just wire a lead from the wiper fuse (12v) in the fuse box to the stereo for the ACC wire and all is well. Stereo even turns off with the car and on with just the wipers if you want. No air bag explosions, no car shutting itself off, etc.
Old 08-29-2005, 01:38 PM
mike_05_sunfire's Avatar
mike_05_sunfire mike_05_sunfire is offline
Re: Sunfire/Cavalier Stereo
I have installed my stereo the exact same way and for 10 months now I have had no problems. But by installing this way I have lost all my warning chimes because what GM has done is put a module inside the factory stereo to control these and have the audibles through the speakers. Now if anyone is really fussy about having their chimes, there is a module out there (part# GMRC01) which plugs into the factory harness, it has it's own speaker for the chimes and you can wire your aftermarket stereo to that without having to run the acc to the fuse box.
Old 08-29-2005, 04:25 PM
matt09524 matt09524 is offline
Send a message via MSN to matt09524
... so that stupid chiming from the door being open or the key in the ignition is coming through the stereo?!
Old 08-30-2005, 10:24 AM
You got it, cause when you take out the factory stereo (like I did) there are no more chimes.
Cheers
Old 08-30-2005, 10:39 AM
That's odd. I was having insurance work done on my car a few years ago and they were replacing the head unit that got stolen. They must have used the factory harness completely because I still get that noise. Stupid GM dealerships.
Old 08-30-2005, 10:50 AM
What year is your car? Cause the class II data bus is in the late model cars (2000 and up) which might be one reason why you still have chimes or second, the interface module was installed.
Old 08-30-2005, 05:08 PM
its a 97 so they must have put something in my car.
Old 08-31-2005, 06:12 AM
It's a 97 so changing your stereo would have no effect on your chimes. 2000 and older vehicles did not have them going through the stereo.
Old 09-03-2005, 05:06 PM
CartmanX CartmanX is offline
Does not having this module affect any other function of the car other then the door chimes. I was looking for a replacement deck for my 01 sunfire as the rear speakers have all of a sudden started working intermittently and the wiring tests fine. They told me I would have issues down the line with second gear in the car, also their may be problems with the airbags, this must be a line of BS please tell me it is?
Old 09-04-2005, 12:52 PM
BlasZ24 BlasZ24 is offline
I'm going through the same thing right now, the guys at the store where I buy all my stereo stuff told me the same thing and that it will affect the ecm, they want me to buy a $150 wiring harness to fix that. Is it actually needed or can the cheaper one without the module be used without giving me engine troubles?
Edit: It's a 2000 sunfire GTw/monsoon stereo stock
Old 09-05-2005, 01:55 PM
I have taken out the stock radio and have not put in anything to replace the factory data bus and I have had no problems at all. But if you want to replace it the aftermarket one out there is only about $70, I would suggest ordering one from an internet supplier as you local stereo shop will always rape you on the accesories.
Old 09-07-2005, 06:05 PM
Ok thanks. I did buy the cheap harness without the data bus and so far no problems despite the guy at the store telling me I would have huge problems and have my car in the shop a few times a week.
