Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-24-2005, 03:08 PM
TheDeal526 TheDeal526 is offline
OCTANE: 89, 91, 93 or 94
Greetings all:
I have a 1989 thunderbird with a standard 3.8 v6 EFI. It has just over 154,000 miles. Does anybody know is a 93 or 94 octane rating better for me than an 89 octane rating. The reason I ask is, I use to have a 1985 Firebird (v8, 305 cubic inches, 4 barrel carberator). On the firebird i noticed an increase in performance with a higher octane rating, so I assumed a higher octane rating would increase performance in any car. back to my thunderbird, i try to buy gas from 1 or 2 companies (Exxon 85%, BP 15%). I use to only use 93 octane. But with rising gas prices, I decided to try 89 octane, and it almost seems like my car runs better with the lower octane gas. Is it all in my mind, or should i continue to use the lower octane? I just assumed that with older cars, it would be better for performance and fuel mileage to use the higher octane (it cost more, so it must be better right). I have to admit also, i do pour a bottle of Lucas (Tune up in a bottel) every month just to keep my fuel system clean and lubricated.
I guess my questions are, what is the difference between octane ratings and how do they relate to a cars performance? And what octane rating should i put in my thunderbird???
Old 08-24-2005, 07:29 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: OCTANE: 89, 91, 93 or 94
You don't have a high compression, high performance motor. Stick with the cheap stuff.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-25-2005, 02:26 PM
how would a high performance motor benifit from higher octane fuel??? wouldnt the lower octane gas dirty a cars fuel system more so than higher octane???
Old 08-25-2005, 05:52 PM
the higher the octane the less prone the fuel is to predetonation. Lower compression motors don't require as much octane unless you start advancing your timing. My '67 Firebird requires premium. It's is around 10:1 compression ratio and initial timing is at 14*. If my compression ratio was higher or I advanced my timing more I would need higher octane fuel than what I can get at the pump to prevent pinging. If your ignition system and your emissions components are in good condition you should have no problem running the cheap stuff.
Old 08-29-2005, 01:30 AM
coondawg6 coondawg6 is offline
just an extra thought is that MOST, not all, but MOST cars get better fuel mileage running the higher octane fuels and tend to get less carbon buildup
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
