Old 05-06-2002, 01:42 AM
shawoo2 shawoo2 is offline
Help with Alarm install.
I will try to make this simple.
My 94 cx has a factory alarm installed.
I am ADDing one of those pager systems that connects to the existing alarm system (see it here http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1342434136).
K, there are 2 ways to set it up. Stand alone or connected to the existing alarm (wait i already said that..).
I tapped all the wires from the existing alarm for the door sensore, trunk, etc etc.
The problem..
The one wire i cannont find is the wire (from the existing alarm) that grounds when the alarm is disarmed. So pretty much when i disarm the factory alarm, the new pager add on alarm also disarms.
I tapped into the black and white wire, however that is the relay wire, it turns on and off, thats it.
Any help at all would be cool.
Thanks.
Old 05-08-2002, 12:57 AM
Still need help, anything would be cool :smoka:
Old 05-08-2002, 07:13 AM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
Get another relay and hook it up to the ground wire for the alarm
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 09:36 AM
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
need help with alarm system jadt00 Legend | RL 3 01-27-2007 10:50 PM
Need help with alarm with starter disable FuLL BLown STD '88 - '91 Civic | CRX | Wagon | Shuttlee 1 05-25-2005 08:16 PM
Need help with Alarm Phat804lude Car Audio 0 04-01-2002 02:42 AM
