Old 08-24-2005, 12:37 PM
Turbogp Turbogp is offline
Send a message via AIM to Turbogp Send a message via Yahoo to Turbogp
Horn Not Working
Hello,
I have a 99 Pontiac Grand Am with the 3400 motor. I recently replaced the blinker and windshield washer unit to fix my previously non-functioning blinker problem. Now my blinkers work, but the problem I have now is that my horn does not function. Is there anyone that could tell me how the horn works, what makes it sound, is there a switch or which wire I would have to look at. Also any other suggestions would be great.
Thank You
Old 08-24-2005, 03:30 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Horn Not Working
Originally Posted by Turbogp
Hello,
Thank You
The horn and the wipers arent on the same circut. the horn has a relay and or fuse. you can test the horn by puting a +pos charge to where green or dark Green wire is and the other to a/the ground somewhere. If the horn works, the fuse/relays are good its in the wire circut somewhere. Did you have the steering wheel off, the wires in there connect the horn switch.hope this helps u out.
Old 08-25-2005, 05:39 PM
Hello,
Thank You
Thank you for the information. I never had the steering wheel off. All that was taken off was the cover around the streering column and the blinker/whiper assembly.
Thanks again.
Old 08-27-2005, 11:52 AM
97grandamld9 97grandamld9 is offline
Banned
Try pushing hard on the steering wheel to get the horn to work, and as you do that turn the wheel. If he horn works and then doesnt work you might have a bad clock spring.
