Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-24-2005, 12:21 PM
golee1 golee1 is offline
1984 LTD wagon proportioning valve
My mechanic says my '84 LTD wagon needs a new proportioning valve, but we can't find one anywhere. Anyone know a place online I could get one?
thanks,
Patrick
Old 08-24-2005, 01:30 PM
reekor reekor is offline
Re: 1984 LTD wagon proportioning valve
1984 if i'm correct that would be the smaller midsize model. In that case you can use a valve from a Ford Fairmont/FUTURA, FORD GRANADA, Mercury Monarch,Mercury Zephyr, Mercury Grand Marquis all of these cars from 1981 - 1984. Or any other Ford/Mercury That has the same brake setup (disk in front and drum in rear) and same wheel base. I would even look into Crown Victoria and Mercury Grand Marquis between 1985 -1990 I dont think there is that much of a wheel base differance for those valves not to work. You may need to mod the mounting bracket and maybe change the line fittings.
thanks,
Patrick
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-26-2005, 09:39 PM
How about a 1979 Granada?
