Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-23-2005, 10:45 PM
ld5221 ld5221 is offline
Question Battery change caused ABS light
I rcently replaced my battery on 2000 Isuzu Rodeo and the ABS light came on. Is there anything that I could do to reset this light? I have the ABS sensor replaced about a year ago and everything was working fine until this battery change.
Thanks.
Old 08-23-2005, 11:09 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Battery change caused ABS light
Disconnect the battery and reconnect and see what happens.
check your ABS fuse too.
After that you will need to have the ABS codes read.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-24-2005, 09:03 AM
wb4lbg wb4lbg is offline
Could just be a coincidence that the light came on after changing the battery. There are two ABS fuses, one in the underdash fusebox and one in the underhood fusebox. Be sure to check both.
If the fuses are good, save some $$ and read the codes yourself. Go to your OBDII connector under the dash and insert a wire between terminals 4 and 12. Then put the ignition switch in the ON position. The ABS light will flash the error codes stored in the ABS module. Each code is a 2 digit number. Count the flashes for the first digit, then for the second digit. Each code is flashed three times. The codes are preceeded by Code 12 (one flash/two flash) and Code 12 will flash again three times at the end.
There's a nice little .pdf with the procedure in it. Maybe I can get Ryan to put it in the FAQ's. If not, post your codes and I will look them up for you.
JWS
'99 LSE 4WD
Old 08-24-2005, 01:17 PM
Isuzu Guy
send me what you have (pdf)
[email protected]
-Ryan
Isuzu Moderator
Car Show Tips
Old 08-24-2005, 07:45 PM
Disconnecting the battery didn't help
Disconnecting the battery didn't help. I'll try to check the codes next.
