Old 08-23-2005, 09:57 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
exhaust install
okay so I just installed my full turbo back exhaust.
Man was it a pain in the ass. Not the removal of the stock exhaust but once I got to the stock o2 sensor housing the problems began. Those bolts must be in the hardest places they can possibily be in to make my job difficult. After about three hours I finally removed all the bolts to the o2 sensor and turned to my new ported o2 sensor for installation. Three hours later and many frustrating throws of the socket and wrench not because of the awkward bolts but because I couldn't get them to go in at all. haha, after that it only took about thirty minutes to get the rest of the exhaust on. So I got the megan downpipe and I decided since I am cheap that I would just go with the tsudo cat back. I was actually suprised because it was rather well made, and it sounds really good actually. Not ricey at all. Nice deep tone. My only problem is I'm sure there is a silencer on the muffler. I would like it to be a little louder. I'm wondering how do I remove this piece of equipment? I saw these two little ass bolts at the end of the exhaust and it looks like part of the inside slides out. I was wondering if that was the silencer. I took a flat head out there and after I removed the bolts I tried to mess with it but I didn't get any place. So before I fucked something up I just decided to turn here. haha
1991 GSX 2.3 Stroker
Old 08-23-2005, 10:06 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: exhaust install
It should just slide out. Was it advertised as a "removable silencer", hopefully it is removable cause it seems like a unnecessary obstruction.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-23-2005, 10:08 PM
ez1286's Avatar
Re: exhaust install
P.S. post some pics if you can.
Old 08-23-2005, 10:09 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: exhaust install
I remember reading unless u get the tool, u use pliars and fight with it to take it out, I have the silencer in mine too, I like it until I get to high rpms
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-24-2005, 01:19 AM
Black97GST Black97GST is offline
Re: exhaust install
Pics!!! Please!
Old 08-24-2005, 06:04 PM
defiancy's Avatar
Re: exhaust install
Here. I couldn't find my camera so I had to take a picture with my camera phone. As you can see I have already removed the two bolts, they went were the two holes are. But I'm pretty sure that that piece inside slides out. Atleast I think.
Old 08-24-2005, 09:32 PM
ez1286's Avatar
Re: exhaust install
Yeah it should slide out. If you can get something lond enough to reach inside it and get a good grip pull it out. It should sound and perform better with that out.
Old 08-24-2005, 09:52 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: exhaust install
What a nightmare it was for me to attempt to install my Megan downpipe. GST's fit fine. GSX on the other hand is a whole nother story!
Glad you got it all done!
DSM geek
Old 08-24-2005, 10:39 PM
defiancy's Avatar
Re: Re: exhaust install
Ahh yeah the downpipe was cake so was the rest of the exhaust. Had to finangle the muffler piece in a little bit but it was pretty easy. Just that damn o2 sensor. Man I have never been so frustrated in my life.
I got that piece out. It required me taking a metal hanger and folding it over until it was nice and sturdy and then taping it all together with electrical tape and make a little hook. It took me all of my strength to get that thing out. haha. It was in there good. But now the car sounds twice as good, and is much louder. I'm really impressed with the exhaust.
Thanks everyone for their input.
Old 08-25-2005, 10:54 AM
Re: exhaust install
Megan GST downpipe =
Megan GSX downpipe =
DSM geek
Old 08-25-2005, 11:39 AM
nova1313's Avatar
nova1313 nova1313 is offline
this has asked before but I never got a really straight answer. what modification can you perform to an exhaust system in a state that does emissions, they do visual check and hook it up to a computer to check the output on it I guess in pennslyvania. I was looking at changing my exhaust but I still wanted it to pass emissions.
I realize I will need the cat but would a high flow cat work also? or wont that pass?
I have 4g64 spyder so i'm kinda limited in what i can do. It's the gs.. should have got the gst... but the price was right...
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 08-25-2005, 12:00 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Re: exhaust install
You can pretty much do anything you want except for removing parts and doing anything to trip a CEL. That means no test pipes, missing mufflers, exhaust leaks or cut outs. Also, don't remove/break your rear O2 sensor.
The only do a visual under car inspection to verify that all of the required parts are there and not leaking. Then they hook up to the OBD-II computer and verify that all of the readiness monitors are set. If everything is set and your exhaust is intact and not leaking....off you go with a $40 sticker.
Hopefully you won't have to go to the dealer and pay $150 like most of us do because of the ECU bug .
Enjoy!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-25-2005, 10:32 PM
nova1313's Avatar
Re: exhaust install
oh I didn't know that was all they did. I thought they hooked up the exhaust to something. SO if I put in a high flow cat and bigger piping it should still pass then? or does it all haev to be stock?
Old 08-26-2005, 07:06 AM
Yes, in pennsylvania that' all they do, I can't comment on other states.
I passed just fine with an upgraded DP & Hi-Flow cat!
1997 Spyder GS-T
5-Speed
Old 08-26-2005, 07:13 AM
nova1313's Avatar
awesome your my new best friend. ^^
So many things to do this week to my car...
