| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
1994 S10 Tailgate Handle Broke
1994 S10 Blazer, Tailgate T-handle fell off along with key assembly. Left hole you can see right thru tailgate.. Can't get upper glass open or tailgate down..Anybody know how to open window & Tailgate so I can take off back panel to replace latch..THANKS
#2 | |
Re: 1994 S10 Tailgate Handle Broke
I had the same thing happen, quite a pain...
In order to get the glass part open, you have to insert an L-shaped object and turn it counterclockwise. (I used a hex-key and a pair of pliers). Try looking for the part that is supposed to be moved! After this, do the same thing turning the key clockwise to get the bottom of the gate open. You might want to reach in with your fingers to find the right spot, I believe it's located to the left, slightly abouve the middle of the hole! Good luck! |
#3 | |
Try to get that thing fixed asap. When I bought my (93) S-10 Blazer it had long ago lost the handle. You can use a screwdriver to open it, but, over time the linkage and release got bent. I tried to replace the handle a while back, but could not get it to work right. Will try again one of these days I guess, but would have been a heck of a lot easier to fix early. You can buy the part off Ebay pretty cheap.
I used to be indecisive, now I am not so sure. |
#4 | ||
#5 | |
Re: Re: 1994 S10 Tailgate Handle Broke
It does take a bit of force to turn the handle far enough. You don't happen to have the push button opener from the dash? That would help a lot! Maybe you should bend a piece of metal in the shape of a Z and try again. It really does work, I've had this problem on two blazers!
Good luck! |
#6 | ||
Re: Re: Re: 1994 S10 Tailgate Handle Broke
