Old 05-05-2002, 11:59 PM
SindeR SindeR is offline
94 si
Hey
im looking at getting a 94 del sol si. I was wondering are the a3 better then the a2? and are they worth building up or should i change it to the a2?
Old 05-06-2002, 03:22 PM
s2Ksol s2Ksol is offline
By what you posted, it seems that you are a little confused or mistyped your question. Here is some facts for you, but check out www.teamdelsol.com for a great deal of information about the del-Sol.
93 sol's had 2 models: S and Si
94-97 sol's had 3 models: S, Si, and VTEC
The 94/95 VTEC models had a 1.6L b16a3 DOHC VTEC engine with 160hp.
The 96/97 VTEC models had a 1.6L b16a2 DOHC VTEC engine with 160hp.
The 93/95 Si models had a 1.6L d16 SOHC VTEC engine with 125hp.
The 96/97 Si models had a 1.6L d16 SOHC VTEC engine with 127hp.
The 93/95 S models had a 1.5L non-VTEC engine with 102hp.
The 96/97 S models had a 1.6L non-VTEC engine with 106hp.
The b16a3 DOHC VTEC engine is a bit more rare, since it was only offered in 94/95 sol VTEC models. It has a OBD1 computer (on board diagosis) that reduced carbons,etc. into the air for emissions. The OBD 1 computer isn't as restrictive as the OBD2 computer, so could yield different/better results if you race, etc.
The b16a2 DOHC VTEC engine was offered for the 96/97 Sol VTEC models as well as the 99/00 Civic Si models. It has a OBD2 computer that is a bit more restrictive for emissions.
Based on what I saw on www.teamdelsol.com the only difference that I found between the b16a3 and b16a2 was the computer and the redline. Everything else was the same, ie hp, compression, torque.
Hope this helps.
Blair 95 VTEC
www.teamsolil.com
Old 05-13-2002, 10:21 AM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
i believe its the same engine.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
