Old 08-23-2005, 08:57 PM
importeater5_0 importeater5_0 is offline
Send a message via AIM to importeater5_0
Fire Starter
ok so im driving and i park my car and i see smoke coming from under my hood so i pop the hood and the area by my coil is all on fire, what could causethis area to catch on fire, i gave my car a tune up yesturday and this happened today, i put in denso iridium plugs, ford racing 9mm wires, and stock cap and rotor, was it a bad wire? was it because of higher power spark plugs? what caused this fire? thanks
Old 08-23-2005, 10:52 PM
Jim Adams Jim Adams is offline
well I think first you have to answer what was actually burning the parts ie cap wires or grease or what? The cap will not just catch on fire neither will the wires,,,what kind of car what year what engine,,,did you accidently crack a fuel line? something like this more than likely happened and not the cap or wires catching fire,,,this is abnormal,,it had to have a flammable to catch fire,,the cap if it had melt down would do just that melt and I dont even think they will melt except under extreme heat. So when you get it back together better be sure because like I said these parts dont just catch fire ,,,fuel or something else had to start it. Good luck!
Old 08-23-2005, 11:00 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
TFI Module
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 08-24-2005, 12:29 AM
Re: Fire Starter
whats the tfi module?
