Old 08-23-2005, 05:48 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
cig lighter not working
when i try to use the cig lighter to charge my phone and my xm it doesn't work. i checked the acc fuse and a couple others but not sure which one is connected to the lighter. does anyone know what fuse it is and if it's not a fuse what else could it be? sorry about the thread title, don't know why my computer decided to put the aom up there
Old 08-23-2005, 10:55 PM
ct91rs ct91rs is offline
Re: cig lighter not working
If your car is pre-'90 or '91 (I don't remember) there will be four torx screws to remove to access the lighter socket, loosen that part of the dash, then test to see if it is getting 12v, If it is, go to a parts store and pick up a new socket for $5, if not you probably have a short and a blown fuse. I don't remember which fuse it will be but it shoult be under the dash with the others.
Old 08-23-2005, 11:07 PM
Nate355RS's Avatar
Re: cig lighter aom
my car's a 92, and it hasn't worked since i bought the car about a year ago. i checked all the fuses and they all look good, i just wasn't sure if someone who owned the car before me might have taken a fuse out or something. so it's probably the socket, good to know that their pretty cheap
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 08-23-2005, 11:36 PM
Re: Re: cig lighter aom
It's a little more work to get at yours. I think you have to drop the steering column (I don't remember) which requires removing the panel and pad under the drivers side dash, so you can remove the piece that goes around the gauge bezel. They you have access to the socket, and ya they are pretty cheap.
Old 08-24-2005, 12:10 AM
Nate355RS's Avatar
Re: cig lighter aom
well i guess i'll give it a shot, worse case scerenio i won't be able to call my girl while i'm listening regular fm
Old 08-28-2005, 12:15 AM
Nate355RS's Avatar
Re: Re: Re: cig lighter aom
actually i looked at it and the fix was about as easy as it could be. the panel that holds the lights, the cigarette lighter, the rear window defroster, and surrounds the guages just pops off. what happened was the metal attachment that gives the ligher the power and pops the lighter out was disconnected, just hooked it up and it works fine.
