Old 08-23-2005, 05:26 PM
jason_pri0910 jason_pri0910 is offline
Question Sidelights
hey i'm sorta new to car mechanics and electrics but, i was wondering;
when you turn your sidelights on then your ignition your dipped beam comes on very dim, just wondering if its possible to stop the dipped beam coming on with the sidelight ? I have blue sidelights but when i turn the ignition on the dipped beam comes on so you can't see the blue sidelights at all. Dunno if this has something to do with the headlight relay or ignition relay or something. thanx
CAR:- 1993 Ford Escort LX 1.8i 16v Zetec
Old 10-05-2005, 05:38 PM
MaxR MaxR is offline
Hello
If you are talking about DRLs that are standard in N.A., then I believe there is a relay that can disable such feature. Is that what you are looking for?
Cheers
2005 Saab 9-5 Aero Estate MTX
2.3L 16V TD04HL-19T 225kW & 410Nm
2008 HSV Clubsport R8 Tourer MTX
6.2L LS3 V8 317kW & 550Nm
