Old 08-23-2005, 05:25 PM
deborah36863 deborah36863 is offline
Send a message via Yahoo to deborah36863
Red face Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I'm a 33 year old female.anhd needing help on my car my car is pulling to the left when i stop. the brakes have been replaced,and keep wearing out on the left side only. i have bleed them but the only one seems to push out ANYTHING is the left.what do i do.My x told me he thought it was a censor not the master .when i called the pontiac place they didnt know what i was taiking about.and the back breaks seem to have no presure as well so just one side working.plus someone put power steering fluid in my breaks.but i dont think it harm the lines because if it did one wouldnt work .i would think all would stop. please help me
Old 08-23-2005, 06:00 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Unfortunately, you have a real problem. First you need to take the car to a mechanic who can totally flush the brake system to remove the power steering fluid from everything. You may unfortunately have to have the calipers, wheel cylinders, master cylinder, abs and brake lines replaced if the system cannot be adequately flushed.
The reason you have the problems you have is due to the power steering fluid not having the same characteristics as brake fluid. The power steering fluid does not compress like the brake fluid and probably boils when the brakes gets hot causing a loss of braking power. Get this fixed asap since you may find yourself with a loss of braking entirely. Once you have this done you shouldn't have any further problems.
Welcome to the forum!!! Sorry for the bad news.
