Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-23-2005, 04:40 PM
jgozolins jgozolins is offline
1990 lebaron won't start
My lebaron will turn over, according to the repair shop it has spark, the injectors are putting in fuel, it is getting spark, and the timing belt is fine and everything lines up. However, it won't start. The computer says everything is working, and it doesn't show a problem with self diagnostics.
Old 08-23-2005, 10:49 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1990 lebaron won't start
make sure your air filter is clean and all hoses/tubes from your air filter going to your intake manifold are free of restrictions. Ask them what color is the spark when they tested it? Was it bright & blue in color or weak & distorted? Also, have a compression test done on your engine, make sure it still can make compression to turn it over.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-07-2005, 11:29 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
use a spark tester on the coil and test the spark output at the coil. do not use just a spark plug. So the injectors are good but is there fuel getting to the injectors, check to make sure that you can hear the fuel pump running. Also, compression test the engine.
