Old 08-23-2005, 04:31 PM
rchmnde3 rchmnde3 is offline
Question Cam/Distributor Keyway
My #1 piston is at compression TDC & I checked the piston itself to make sure my marks on the pulley aren't off. The keyway is either at 12:00 or is a hair off. Is it supposed to be plum or is the engine at a slight angle & would the keyway also be at an angle?
I think either my timing belt is off or the rotor shaft in my distributor needs adjustment if that's possible. The car was driven out of time a little. In any event I cannot rotate the distributor enough to get the timing right or even acceptable.
Old 08-24-2005, 09:24 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Cam/Distributor Keyway
Hi Noob, welcome to the forum!
I'd have to guess the timing belt is off a tooth or two. When putting on the timing belt the side of the belt closer to the front of the car should be tight. Otherwise when the engine turns over your timing will be off. GL
Old 08-24-2005, 11:00 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the engine does sit at an angle so the key is also angled. if you were to look from the side of your car straight onto the motor, the key would be at 11oclock, thats normal.
as far as your dizzy(aka distributor) the belt may have jumped a tooth or two. if your not comofrtable with loosinening up the tensioner and adjusting it yourself, just have a shop do it for you.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-24-2005, 11:53 AM
Thumbs up
Hello forum & thanks for your response; johnb16a2 & crxlvr:
The timing marks on the camshaft sprocket seem to be dead on. Could the camshaft still be off; or should I start leaning towards the remanufactured dizzy?
Old 08-24-2005, 01:16 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if your crank and your cams are all aligned at tdc, the rotor should be facing toward #1, is it?
Team Lonely Drivers
Old 08-26-2005, 06:28 PM
Re: Re: Cam/Distributor Keyway
The marks on the cam sprocket seem to be aligned at TDC and the keyway seems to be at 12:00.
Old 08-26-2005, 06:32 PM
The rotor does seem to be few degrees clockwise of where it should be, but it is pointing in the general vicinity of # 1.
