Old 08-23-2005, 02:08 PM
chevelleman chevelleman is offline
Send a message via AIM to chevelleman Send a message via MSN to chevelleman
could my pcm be toast?
right now i am having problems with my 94 Z28 m6 sometimes it will start and run fine and once it gets heat soaked it will either shut off or once you shut it off it wont restart it will hit a couple times but thats it but anyhow when its running its throwing a code i believe its the egr failure code i got out of it awhile ago with a scan tool but im not sure so i tried to get the codes out of in manually by jumpering the diagnostic port with the ground port (12 pin OBD connector) the cooling fans come on like they're supposed to but it will not throw out any codes not even a code 12 it wont blink period
so is my computer toast or whats going on i believe i got the problem traced back to the ignition module or the coil but if the computer is screwed up that could be whats wrong as well i have tried to get codes out of it before when the car was running fine so its nothing new that i havn't been able to get the codes out of it
1994 Camaro Z28 Hooker catback, SLP cold air intake, smooth intake bellows, dynotech dynaspark distributor, MSD super conductor wires
Best time 13.902 at 100.51mph 60 foot 2.002 on street tires
Old 08-23-2005, 03:00 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: could my pcm be toast?
can you short the pins on a 94?
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 08-23-2005, 04:31 PM
i thought you could but i could be wrong i figured since it was OBD I and it still had the OBD I 12 pin connector that it would work
Old 08-23-2005, 10:20 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
you cannot flash codes on a fourth gen, you have to use a scanner. hotwiring the leads on a DLC in a fourth gen might cause some sort of electrical damage, so if it wasnt toast before, it might be now. get a scanner and check it out.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 08-24-2005, 09:08 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
jumping A to B on a OBDI hybrid may cause damage to the body control module.
Old 08-24-2005, 09:50 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
It won't damage anything but will not flash codes. Only 4th gen that will flash codes is 93. 89 is correct you need a scanner or a OBD 1 cable and then you can scan the codes with your PC or laptop.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-24-2005, 11:36 AM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
now back to the toast question....... if you throw some butter on it why not....
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 08-24-2005, 11:37 AM
89IROC&RS's Avatar
i like having teeth.......
Old 08-25-2005, 01:04 AM
well i went ahead and did it i ordered a PCM i figured it had to have been the computer because of all the goofy stuff it was doing i would turn the key on and every once in a while both cooling fans would turn on and if i was able to get it running it would die right away and then the air pump and the fuel pump would cycle on and off even though the motor wasn't running when it wouldn't start at all you could cycle the ignition on and off a few times and usually get it to hit a couple more times some goofy stuff going on there
but anyway just to make sure i disconnected the 4 prong connector from the ignition module and by turning the motor over you should get an AC voltage from the computer to cycle the ignition module and i got nothing so im pretty sure its the computer and i hope cause i ordered the damn thing so i hope it work
wish me luck
