Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-25-2001, 12:35 PM
maximike maximike is offline
Question security lock
purchased used 92 gxe. only door lock that works with key is passenger. once open all power locks work. i located code under dash and when entered it beeps but does not unlock. is there more i shoud do. also any info on door key lock replacement would be appreciated. thanks
Old 07-25-2001, 02:30 PM
shemp77 shemp77 is offline
Use 7 digit code to enter your 4# PIN
I don't know anything about only your passenger lock working, but I think I've got some info on the key code. According to my manual, you enter the 7 digit code and that allows you to set up a 4 digit PIN that will be your new code. The 7 digit's like the master. If you've got a manual, check it out.
So you were able to locate the 7 digit pin under the dash. Where exactly was it? I've been trying to find it for awhile. If you don't have a manual let me know and I'll get you the instructions on setting up the 4 digit pin.
Old 07-25-2001, 04:26 PM
tag with code is difficult to see but you lay on the floor and look behind glove box next to blower motor with flashlight you should see it.
we just picked up this car yesterday and have no manual. i will try entering the code and then a 4 digit number. thanks for any help
Old 07-26-2001, 06:52 AM
Talking
Thanks, I found it.
Yeah, you push the st/cl button, enter the 7 digit code, and it should make a long continous beep. During this beep enter any 4-7 digit code you want. Then it will make like 6 short beeps-which is what's supposed to let you know the code was entered correctly.
One other thing. I talked to an old buddy of mine who is a nissan mechanic. He said one of the things with the keypad stuff is that the buttons commonly go out, so if everything goes cool, but still doesn't seem to work, this might be it.
