Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-23-2005, 12:00 PM
blackbus blackbus is offline
'01 DRL and Fog Lamps don't work
I recently purchased an '01 suburban to replace my trusty old '98 short bus (170,000 flawless miles) and can not make the Day Time Running Lights or the Fog Lamps work. There does not seem to be a fuse specifically marked DRL or Fog in the fuse access panel on the left side of the dash. Is there one located else where on the truck? What other relays/switches send power to those lamps?
I have checked the circuts with lights on, lights off, in drive, in park etc, etc, and don't seem to be getting any power to either set of bulbs. What should I check next?
Thanks!
Old 08-23-2005, 04:04 PM
2000CAYukon 2000CAYukon is offline
Re: '01 DRL and Fog Lamps don't work
Push the Dome Override button 4 times really fast to see if someone disable the DRLs. You should hear a chime if you do it right.
On my 2000 Yukon, the fog lights only come on if the headlights are on and it is in gear.
//2000CAYukon
