Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-23-2005, 10:37 AM
carless22 carless22 is offline
pushrods and rotating rocker arms
we took the engine apart to exchange the intake manifold gasket, but we did not lable the pushrods when we removed them from the rocker arms. How can we find out to put them back in the right order? Any suggestions?
Old 08-23-2005, 11:21 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Too late now! But as long as the ends are smooth and shiny you should be just fine. Run a piece of wire through them to make sure they are not clogged up. Also look at the rocker arms if you find anything wrong with them.
Old 08-23-2005, 12:00 PM
Re: pushrods and rotating rocker arms
The rods have diff. lengh we had them in, but (I guess) wrong because the car is not driving right.
Old 08-23-2005, 08:10 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Re: pushrods and rotating rocker arms
Well it is too late now, the damage is done.
With the wrong pushrods installed, you have bent some valves..time to pull the heads off
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-23-2005, 08:16 PM
bearcatdon bearcatdon is offline
Exhaust is the long one 6" and intake is the short one 5 3/4". If you follow the path of the manifolds they will tell you which valve is which.
Old 08-23-2005, 08:19 PM
Re: Re: Re: pushrods and rotating rocker arms
Maybe he got lucky and didn't place one of the pushrods on the cam properly.
Old 08-24-2005, 07:03 PM
GMMerlin's Avatar
I know stuff
Re: Re: Re: Re: pushrods and rotating rocker arms
Then he should play the lottery!
The chances of getting those pushrods in the right position if he didn't mark them when he took them out is slim and none.
At least he saved money doing it himself
GM WCT
PM Me for details
Old 08-26-2005, 09:00 AM
garync1 garync1 is offline
As what you mean is label the ones if you are going to re use them??
If you have the exhaust push rod tube correct size and intake tube correct size it not that important... If you are worried than just buy a new set of push rods. But just make sure the correct size is in exhaust and intake.. I have seen most mechanics just throw them to the side. Come back later and put back in.. in no real order just correct sizes in the exhaust and intake sides. You may have to adjust the valves a little. what happens is the wear on the push rod may throw the valves off a little.. If you never got it fully running it may not have done much damage.
