Old 08-23-2005, 09:27 AM
value value is offline
Distributor cap
No joke, serious question.
My 95, 4.3. Can the cap be removed without taking anything else off the engine??
I can’t see the rear screw and it looks like it may have a hard time fitting between the intake manifold and the firewall!!.
Forgot who posted this, but I took his advice and dropped the steering box shaft and getting the spark plug out was easy. Also saved on getting tools that I didn’t have on hand.
Thanks, LS
Old 08-23-2005, 10:35 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Distributor cap
Just use a loooong screwdriver to poke down between the wires on the front and back of the distributor. You'll find a pair of regular phillips screws under that tangle of spaghetti. Transfer your wires from your old cap to the new cap, (one at a time to avoid mix ups) replace the rotor "bug" just under the cap too - screw her back together. Tighten up the screws until snug. No more, no less. Good luck.
Old 08-23-2005, 02:46 PM
Re: Re: Distributor cap
[quote=wolfox]Just use a loooong screwdriver to poke down between the wires on the
Thanks;
I'm on it.
Old 08-23-2005, 02:54 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Distributor cap
The screws are righ on top of the distributor cap. Get right over the engine and look.
Best to take the wires off the old first and plug them into the same connection on the new cap. This saves screwing things up.
also, hope you are replacing the rotor along with the cap, ALWAYS replace them as a pair.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-23-2005, 04:59 PM
97BlazerDude's Avatar
97BlazerDude 97BlazerDude is offline
Re: Distributor cap
Thanks, LS
On my 97 4.3L, I did not have to remove any other engine parts. Mine was not a phillips head, but a Torx head screw. I lost like three torx bits back there before I finally got it off (found most of them once the cap was off). The front torx screw size will usually matches the back torx screw, so use the front one to figure out what bit or socket or fitting to use (probably T15 or T20). There is an indentation (half circle) on the cap that will guide you to the back screw.
I can wear a blazer. I can drive a blazer.
Old 08-23-2005, 05:12 PM
wolfox's Avatar
Re: Distributor cap
97 and early 95's have completely different cap and rotor layouts. Mine's the type with the wires sticking vertically straight up our of the distributor. Old skool, I know - but she has phillips screws holding it down.
Old 08-24-2005, 10:56 PM
[quote=wolfox]97 and early 95's have completely different cap and rotor layouts. Mine's the type with the wires sticking vertically straight up our of the distributor.
Got back here today equipped with a five-foot screwdriver and ready to go.
Bought new cap, rotor and wires but the new cap has the terminals flat out the side, not straight up like my old one.
Guess that will be OK, huh??
Old 08-25-2005, 08:17 AM
herkyhawki herkyhawki is offline
Re: Re: Re: Distributor cap
[quote=value][quote=
Guess that will be OK, huh??[/QUOTE]
Not OK. Check your new plug-wire set too! If you want to keep this simple, go get new cap and wire set same as your old one. The wires do not plug in the same order on the horizontal one. You may have to tell the store it's a '94 to get the right one.
Old 08-25-2005, 08:22 PM
Re: Re: Re: Re: Distributor cap
[quote=herkyhawki]Not OK. Check your new plug-wire set too! If you want to keep this simple,
Thanks, you saved me a big headache!
Had no idea, will change for same.
Old 08-26-2005, 08:10 AM
Re: Distributor cap
Also see the "firing order" thread. It shows the 2 different dist. caps.
http://www.automotiveforums.com/vbul...d.php?t=449353
Old 08-26-2005, 10:29 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: Distributor cap
how much would it effect engine proformance if one side of the cap was striped out but the other side fit nice?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
