Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-23-2005, 09:43 AM
carless22 carless22 is offline
overheating
I have a 2001 Malibu with 98.000 miles. My car is overheating after I drive for a short time the antifreeze is blowing out of the overflow and when I start it again it tells me low on coolant. We changed the thermostat, the intake gasket, the waterpump is working good, the heat gasket is not leeking- what could it be?????????
Old 08-23-2005, 09:50 AM
BeatnikTermite BeatnikTermite is offline
Have you tried to replace the Overflow Tank Cap? The seal can rot away, not allowing the tank to hold pressure, and causing an overflow.
Be true to yourself and you will never fall.
Old 08-23-2005, 09:05 PM
bearcatdon bearcatdon is offline
Re: overheating
Is your fan working? Turn the A/C on and the fan should start up. If it doesn't you need to verify the relays and fan connections. When your temp gauge gets to approx. 3/4 of the way, does the fan kick in? If not you probably need another sensor.
