91 PA lights are out
The low beam headlites quit. High beams work. All fuses under the dash seam to be fine. Lights don't work with switch or the automatic light sensor. What can I do to fix them?
Re: 91 PA lights are out
since both of them are out, I'd check a relay. I dont know off hand how the headlight relays work, but I would assume one would control the highs and one would do the lows. Check relays in the maxifuse center using a manual to find the right one, or by elimination.
It would be worth a try to check it out...since anything may happen with poor relays.. 2KU |
Also check the twilight sentinel, this seems to be also a source for errors with the lamps.
Nevertheless, before you start, check if there is power on the connectors of the lamps. Then go all the way (you will need a wiring diagram) and check all elements - switches, relays, fuses.
For road: Buick Park Avenue 1992 3.8l For off-road: Jeep Cherokee Laredo 1988 4.0l For fun: Chrysler Imperial Crown 1963 (413 cui, 340 hp) |
