Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-23-2005, 02:45 AM
greyjeep greyjeep is offline
overheating issues on an 89-need help!!!
overheating issue- I live in AZ, so overheating is not out of the ordinary but i have had this jeep for 3 years and this is the first with problems. I have changed the thermostat, bought a bigger radiator(3 core), changed the hoses, fluid, rad. cap and still have issues. sometimes it is ok and will not overheat but for the most part it overheats. I have run out of ideas. Anyone know what it might be?
Old 08-24-2005, 08:29 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: overheating issues on an 89-need help!!!
I'd take a look at and think about changing the thermostat and the water pump. Seems you've done everything else.
Oh yeah, is there a shroud on the fan, or is it open? A shroud will increase your airflow and help with cooling.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-26-2005, 01:44 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Headgasket? Are you losing any coolant?
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 08-27-2005, 09:05 PM
CanaMark CanaMark is offline
Shroud will cause overheating at idle. Mine has no shroud and over-heats at idle. But never will moving all the time like on the highway.
Old 08-27-2005, 09:31 PM
89ltd 89ltd is offline
try the fan clutch as well.
Old 08-29-2005, 02:41 AM
OK I have changed the Thermostat, Can the water pump go out with actually bursting?
How can you tell if it is the fan clutch? Does anyone have any troubleshooting tips as to how to tell when it is going out?
The jeep will overheat especially when running on the highway. It does not have a leaky head, I have checked oil and have checked tail pipe. Thanks for the great tips!
Old 08-29-2005, 07:51 PM
The fan clutch is on the fan right behind the fan blades, which has 4 bolts to belt pully. Could be the water pump, easy enough fix, just replace it.
Are you'r belt(s) tight? Are they squeeking?
