Old 08-23-2005, 01:31 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
T-case fluid
My friend and I dropped his oil pan to replace the gasket and drained the t-case fluid in the process. What are we supposed to put back in? The haynes manual wasnt much help... it just said something about gear lube. Would I use the stuff for manual transmissions? What weight fluid should I use?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-23-2005, 07:36 AM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
this is what i have used for a long time as well as many others,it can be found at autozone.its around $5.00 a quart but if you just want some gear oil use 75w-90 then.if you really love your tranny put in BG SyncroShift (Transmission) it will love you for it.
http://www.pennzoil.com/products/gea...cro_fluid.html
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 08-23-2005, 12:28 PM
Thor06's Avatar
Jizzed In My Pants
Use 75W-90 gear oil in the transfer case? Sorry if I was unclear, the tranny fluid is ok, we just need transfer case fluid.
Old 08-23-2005, 02:30 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: T-case fluid
75w-90 gear lube is fine for t-case.
On a side note about the oil pan gasket...I just did mine and used a fel-pro gasket with Red RTV. It leaks. Now i researched this on tuners and found out that from the factory they came with no gasket and just RTV as a sealant. The aftermarket replacement is Ultra Grey RTV.
Let me know how it turns out for you since i will be doing it again soon...
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 08-23-2005, 06:40 PM
Thor06's Avatar
Jizzed In My Pants
Ok, thanks guys, I appreciate it. I will let you know when we get the oil in... we need the oil return pipe gasket yet.
Old 08-23-2005, 09:56 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: T-case fluid
I replaced my rtv with a gasket and it leaked terribly so i ended up pulling it off again (mine awd too so a lot of work) and just putting on rtv. btw i used 80w-90 valvoline durablend synthetic, worked great.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
