Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-22-2005, 10:24 PM
crazy torino's Avatar
crazy torino crazy torino is offline
Send a message via MSN to crazy torino Send a message via Yahoo to crazy torino
Question bigger not always better or is it
ok i know for running a big 16 g turbo you'll get about 20-25 psi and you want to run about a 34- 38 waste gate corect anything bigger you loose boost. so what about a header the bigger the header the faster the spool right ? Mitsubishi Eclipse DSM SS T4 Monster Turbo Header vs Mitsubishi Eclipse DSM SS T3 Turbo Header.
Old 08-22-2005, 10:28 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Re: bigger not always better or is it
If I understand what your talking about correctly, I would still suggest a factory 2g, Evo, or one of those new fangeled SBR exhaust manifolds. There is no reason for anything fancy on a 16g setup.
I wouldn't worry about the spool in regards to the turbo in question.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 08-23-2005, 12:25 AM
2of9 2of9 is offline
man... i forgot, but why is the 2g exhaust manifold better than the 1g exhuast mani?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 08-23-2005, 12:35 AM
Whathits14 Whathits14 is offline
Bigger runners = more flow...just like the 1g throtle body, head, and intake manifold are better than the 2g's....easier flow for the air you are pulling with your turbo. Gains will be minimal with a fancy $500 manifold on a 16g; its a small turbo. Bigger is not always better.... 65 trim on a streeted car is usually over the top with your spool so late.
VFAQ has some photos comparing various parts in the 1g and 2g, eg throttle body, mani etc etc...
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 08-23-2005, 07:57 AM
Re: Re: bigger not always better or is it
Typically the 1g tends to crack while the 2g mani doesn't (but can).
Aaron B.
52.7 1/4 second try
6.6 55 meters
