Old 08-22-2005, 10:06 PM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Melted power wire
I was taking my equipment out of my truck to take it to the shop and I pulled the inline fuse under the hood. I noticed that the clear plastic fuse holder was cracked the power wire after the fuse was all brown and looked like the outer cover was starting to melt. The only thing I can think of is that the fuse is too big for the power I'm running. I'm running about 500 watts rms 800 peak on a good day. And the fuse is a 50 amp. Is that too big or what else could have caused that to melt? I thought the fuse was supposed to blow before anything melted or shorted out.
Old 08-22-2005, 11:26 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
Re: Melted power wire
what guage wire?
Old 08-23-2005, 12:12 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
4 maybe?
Old 08-23-2005, 11:29 PM
I had to go find my old amp kit box. It was 8 gauge and it originally came with a 60 amp fuse, so I must have picked up a smaller one somewhere. Is 8 gauge too small? When I first started building my system I asked the guy at mickey shores and I told him everything I had and he said that should be good. On the outside of the box it says up to 300 watts. So If my amp is 760 max I should still run under 300 rms. Right?
Old 08-24-2005, 04:50 AM
Havoc724 Havoc724 is offline
Send a message via AIM to Havoc724 Send a message via MSN to Havoc724
How far is your fuse from the battery?
8g power wire is fine if you're only running 1 amp thats 300rms. If I remember right, I had a 40amp fuse with my 8g wire. I was running like 400 maybe 500rms w/o any problems. I've heard of that when you overload a wire like my friend did running 2 amps off a 8g wire. The whole thing melted and blew the fuse.
2006 Scion tC
Nothing Yet...
Old 08-24-2005, 09:06 AM
the fuse holder was 6 inches at the most from the battery.
Old 08-24-2005, 11:58 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
an 80A fuse may be a bit too big for an 8 Ga wire.
Old 08-24-2005, 12:40 PM
shit, my 4ga has a 60 amp fuse
Old 08-24-2005, 03:04 PM
No. the amp kit came with a 60 amp and when I pulled it apart the other day I had a 50 amp in there. So it should have blown sooner.
Old 08-24-2005, 05:14 PM
ToyTundra's Avatar
maybe it melted from engine heat
Old 08-24-2005, 06:14 PM
thats what i was thinking
Old 08-25-2005, 07:26 AM
I would have to doubt that. Who ever make the wires knows it has to connect to the battery, which is under the hood and they should know it can get hot under there. Plus were it was burnt was right on top of my radiator resivior. And that was plastic so if the wire melted I think the plastic resivior would have melted first or looked discolored which it wasn't. And the whole wire wasn't burnt. Only about 3 inches right after the fuse holder.
Old 08-25-2005, 11:19 AM
ToyTundra's Avatar
Hmm. 8 awg should be able to take 50A (I've done it). I'm stuck.
Old 08-27-2005, 09:29 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Your ground might have something to do with my friends ranger melted the power wire about 6 inches and it was becasue his ground 3' long. Made it 6" long and he hasnt burnt it up since. Either that or you have to much power running through the wire.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-27-2005, 10:48 AM
The amp is in the extended part of my truck right under my enclosure. And the ground wire is only a foot long at the most. I un-bolted the seat and sanded the paint off and bolted it back down, so it should be getting a good ground.
