Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-22-2005, 08:54 PM
98camrycincy 98camrycincy is offline
Cool 1989 Accord Oil Pan leaking...help
I have a 1989 Accord LXi. I brought it to the mechanic to have him troubleshoot a check engine light, and he told me that I needed to replace my oil pan because it has rusted through. What I need to know is how difficult is it to change the oil pan? Do I have to remove major components or structures such as suspension and axles? Any help is truly appreciated. This is a great way to share information.
Old 08-25-2005, 11:10 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: 1989 Accord Oil Pan leaking...help
the only thing you should have to do is remove the B-Pipe exhaust. Than take out the 10mm's holding on the pan.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
