Old 08-22-2005, 07:32 PM
styx123 styx123 is offline
high oil pressure
what is going on when the oil pressure gauge rises to max when accelerating and drops to 30-40 when idiling?
Old 08-22-2005, 08:06 PM
Bads Crew's Avatar
Bads Crew Bads Crew is offline
Re: high oil pressure
30 to 40 is great oil presure at idle. When your RPMs raze so will your oil presure. If you think you have a gauge problem I would change the sending unit.
Old 08-22-2005, 08:27 PM
Re: Re: high oil pressure
well I am trying to figure out some engine noise (squeeking). the oil pressure hasn't been that high until about 2 months ago. when I am driving regular the pressure gauge reads 80+. I am wondering if the oil is not getting to all the places it needs to.
Old 08-22-2005, 08:48 PM
Bads Crew's Avatar
Re: Re: Re: high oil pressure
I would disconect the serpentine belt and start the engine if there is no squeek you know its not in the engine. Having had a 87 myself I'm guessing its the belt tension pully. With the oil presure try and change to sending unit. I dont think oil presure is your problem unless the truck over heated bad before and the oil got fryed to the block.
Old 08-22-2005, 10:03 PM
Bads Crew's Avatar
Re: Re: Re: Re: high oil pressure
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx
Old 08-24-2005, 11:30 AM
tom3 tom3 is offline
My truck did this same thing while under warranty. I expected the worst, but they replaced the pressure sending unit and it fixed the problem. Might look into this.
