Old 08-22-2005, 06:58 PM
chinosgrl chinosgrl is offline
hooking up system
I need help my boyfriend doesnt seem to think i can do this and i want to be able to show him that i can. you see i need help hooking up my stereo system I have a pioneer single cd player in my blazer i have speakers in the dash, kick panels two doors in the front and speakers in the two rear doors and a amp in the back area any help will be apreciated thank sooooooooooo much
Old 08-22-2005, 08:26 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: hooking up system
Honestly, this is not something we can teach you over the internet, you can online learn from hands on experience and a knowledge of electronics.
You do know you have to replace the door speakers when you replace the cd player or it won't sound great al all seeing the cd player is geared for 4 ohm speakers and the stock speakers are 6 ohm I think.
Result, you won't get a as much sound from your speakers.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-22-2005, 09:55 PM
gorgon2k's Avatar
gorgon2k gorgon2k is offline
Send a message via AIM to gorgon2k
im an installer, i guess i can answer the basics. what year is it to start?
Old 08-22-2005, 09:58 PM
gorgon2k's Avatar
nm, i saw youve got a 95. unfortunetly they are a pain in the butt. to get the radio gotta remove the whole dash from climate over. AND BE CAREFULL of your hazard switch, its very expensive to fix. its a pain to get that dash in and out.dash speakers are easy as can be, and doors are simple, a few screws and panel pops.
Old 08-22-2005, 10:00 PM
gorgon2k's Avatar
the system isnt factory amped is it?
Old 08-22-2005, 10:18 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
you need to change the speakers.My dad did not listen when he put the 70x4 in his 01 in June and now the back one is blown
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 08-22-2005, 10:51 PM
BlazerLT's Avatar
AF -Advisor
No you don't, I watched the installers install my aftermarket CD player without removing the dash.
Old 08-23-2005, 01:22 AM
I have a 95 you see the cd player is already in I have changed all speakers im just not sure about the amp and the wiring i have a sony amp
Old 08-23-2005, 01:23 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: hooking up system
realy like to know how the hell they did that, theres 2 screws holding in the radio and a cross bar between the HVAC and stock radio...
Old 08-23-2005, 04:12 AM
00BLZRMyWay 00BLZRMyWay is offline
If you really wanna outsmart your boyfriend or show him that YOU CAN DO IT, there's a lot of details and tricks to installing an amp. It's quite simple actually after doing it once of twice though. Don't let me discourage you though, I hope that I can encourage you to learn how to install an amp. Like LT said though, it would be a lot better if you got some kind of detailed instructions or got a local stereo shop to let you in on some details. Unfortunately, it is hard to find a shop that'll do that. Most shops will just say "Oh we can install it for you!" Then they'll try to get your business by saying "We won't charge you labor!" But really, they'll be selling you a Capacitater (Cap.) and installing it on a low power amp that doesn't even need it. Sorry, got carried away there. But hey, there you go. Outsmart your b/f with that info. I can give a description of how to install an amp, but I don't think it'll get you goin'. Just post a "yes" or something if you want a description.
K&N won't honor my warranty because I have 1,000,007 miles on my Blazer
Old 08-23-2005, 08:37 AM
XPC2004's Avatar
XPC2004 XPC2004 is offline
Send a message via MSN to XPC2004 Send a message via Yahoo to XPC2004
Re: Re: Re: hooking up system
I did it! I did it! (and I am proud of it too!)
I'll get some pics when I find my cam, but here is the jist of it...
1) Unhook neg cable from battery
2) Pop the front panel off covering the radio,cluster.. it just pops right off (not too technical, please feel free to add info here)
3) Unscrew the two bolts holding in the instrument cluster cover, and two under the dash holdign it down there.
4) Drop your blazer into 1st, and push your hazzard switch down (you'll have to turn your key and press the brake real hard , and drop the tilt all the way down. (you might have to really lean on your brakes to do a little shimmy)
5) Carefully and gently pull the cluster out, it will come out with a bit of play, remove the 4x4 switch and any other conenctors you feel you would like to remove (I left everything attached, except for the 4x4 switch, changed my bulbs too...)
6) Now you have access to your radio, undo the four bolts holoding it in two top and two bottom (you may want to remove the climate control too, gives you soem room to move cables around once you've installed your radio)
7) remove your radio, install new one with proper dash insert, ect, then just reverse this processs.
It took me about 1hr to do it properly, I also had to take a hack saw to enlarge the dash area for the radio, the aftermarket system was a few inches longer, and it made for a perfect area for the cables to lay out of the way.
Phew... I'll get pics for this weekend.
Xpc... truck still running... better catch it...
Old 08-23-2005, 08:52 AM
GirlBear's Avatar
GirlBear GirlBear is offline
I replaced the shitty factory with a JVC mp3/wma deck installed an amp and a 15 inch Cerwin Vega w/box. Took a little over 5 hrs. 99% of installation time was running power from amp to the battery. Ask me anything and Im sure I can help ya with it. Proving that chicks are capable of doin this stuff too.
http://jowulf.deviantart.com/
Old 08-23-2005, 08:56 AM
GirlBear's Avatar
Re: Re: Re: Re: hooking up system
I guess I should've read the entire thread. Nice job anyway. It was easy right? Chicks RULE!!!
Old 08-23-2005, 09:10 AM
XPC2004's Avatar
Re: Re: Re: Re: Re: hooking up system
It was easy, very easy... so easy that I shook my head at the thought that I would have paid someone $45 do install it (that's canadian dollars)
This was the first stereo I installed ever in an suv, my 78 firebird was easier, no cutting, just drop in and done.
Chicks do rule! We men just sit back and admire all the rulin chicks with a beer in one hand (or a nice tall glass of rye and cola..mmmmmm) and the remote in the other hee hee...
Old 08-23-2005, 10:56 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Has anyone fabbed their own mounting plate? I don't like the way they stick out. Or is it a needed due to depth issues?
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
