Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 08-22-2005, 07:53 PM
MIKE FAHEY MIKE FAHEY is offline
2000 Sonata Will Not Start
Hope Someone Can Help! Engine Will Crank Over But It Will Not
Start. I Checked The Fuses Under The Hood And Found That The
Fuses For The Ecu & The Injectors Do Not Have Any Current
Going To Them. Where Do They Get Their Current From & What
Color Is The Power Wire For These Fuses?
Thanks In Advance,
Mike
Old 08-24-2005, 08:57 AM
SteveB05's Avatar
SteveB05 SteveB05 is offline
Re: 2000 Sonata Will Not Start
You will likely need to get a manual with a good electrical diagram. http://www.alldatadiy.com has good stuff for my other vehicles. I haven't looked for stuff for my Sonata. Anyway, you may have another blown fuse, or possibly a bad ignition switch.
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
Old 08-24-2005, 03:28 PM
twospirits twospirits is offline
Ex-Janitor of AF
All data is a good place, but you would need to pay for the subscription, I would suggest you go to Hyundai Webtech, just sign up and look up the diagrams for your model.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Old 03-23-2006, 04:14 PM
ebolen ebolen is offline
I have the same problem did you ever find a resolution for your problem. Im not getting any spark or gas. but all fuses are good. and it cranks fine.
Old 05-01-2007, 10:54 PM
chubbygoatboy chubbygoatboy is offline
I would like to resume this post. I have a 2000 with 66k on it. It ran fine, but needed a new battery. I replaced it, and it has not started since. It cranks fine, and I removed fuel line off of the rail, cranked it, and it shot gas several feet. I then checked, and it is not getting spark. ANY IDEAS?????
Old 05-24-2007, 08:42 AM
Any ideas yet? I did get a crank position sensor code, so I replaced the crank position sensor, still it only cranks, no fire, and the code still shows up after I erase it. ?????????????????
Old 03-20-2009, 03:54 AM
kennyspackers kennyspackers is offline
Balance shaft belt grooves are gone, need a new "bowtie" (can't remember the real name) it sits behind the timing belt, crankshaft gear
Old 03-21-2009, 08:55 AM
jsinton jsinton is offline
Did you check the timing belt? Remove the top cover, and see the condition of the timing components.
Old 09-20-2009, 11:32 AM
alexarav's Avatar
alexarav alexarav is offline
My 01 Sonata is expiriencing the exact same problem at the top of the thread! Engine suddenly died, cranks fine, wont turn on...cant figure out the problem. This seems to be common with these cars..Anyone here find a solution for this?
