Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 08-22-2005, 06:30 PM
sonny28 sonny28 is offline
Send a message via MSN to sonny28
Exclamation plz help 1995 2.0 jetta
pls help 1995 2.0 jetta runs good sometimes like junk others hesitation at 3000-4000 rpm when i acc car get louder but it gos slow clutch is not sliping just no power lot of noise what is the deal oh yeah back bumper turning black at tail pipe has flow master no cat cold air intake new fuel filter 97 octane gas new plugs wires dis cap roter button cant fig it out someone tell me somthing plz
Old 08-23-2005, 07:51 PM
boschmann boschmann is offline
Re: plz help 1995 2.0 jetta
It sunds like a clogged catalytic converter.
Old 08-24-2005, 04:49 PM
i already removed the cat
Old 08-26-2005, 04:39 PM
Try checking the coolant temp sensor on the upper radiator hose flange. 2000-3000 Ohms cold, 200-300 Ohms hot.
Old 08-28-2005, 09:30 PM
ok i checked the temp sen its good
Old 08-29-2005, 12:08 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
You should not run 97 octane in a 2.0.... Sounds like your piston rings are not sealing properly. Check the compression and cylinder leakage.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-29-2005, 06:04 PM
oops i ment to type 93 octane gas sorry
Old 08-30-2005, 08:04 PM
You need a scanner with datastream to check the mass air flow meter. It will have to be a VAG or VAG-COM scanner.
