Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-22-2005, 06:06 PM
mkemp0113 mkemp0113 is offline
Question 95 T-Bird - I need help!
I have had the battery and alternator tested - they both test out just fine. I replaced the positive connector on the battery after I found a little corrosion. It has been an on again, off again cranking process. Sometimes it will crank, sometimes it won't. When it decides not to start, it makes no sounds whatsoever - none - however the radio, clock, etc. never loses its memory. If the car runs for a little while and it won't restart - I can wait an hour or so and it will start right up - no hesitation. My next venture will be to check the starter - why, if the starter is bad, will it crank - and then after it runs for a little while it won't crank? Any help is greatly appreciated!
Old 08-22-2005, 08:25 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: 95 T-Bird - I need help!
What engine is in it?
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-23-2005, 01:52 AM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
Sounds like the starter...starters do that sometimes..
Usually they go dead..and that's it...but sometimes the starter will have a little life in it, and hook sometimes.. I forgot the name of the mechanism in the starter..but it wears down, and sometimes you can actually BANG the starter with a wrench while someone is trying to start her up..and the mechanism inside the starter will hook..
"And Death Shall Have No Dominion"
Dead men naked, they shall be one
With the man in the wind and the west moon
When their bones are picked clean and the clean bones gone
They shall have stars at elbow and foot
Though they go mad, they shall be sane
Though they sink through the sea
They shall rise again
Though lovers be lost love shall not
And death shall have no dominion.....
....Dylan Thomas....
Old 08-23-2005, 07:47 AM
It has a 4.6L V-8
Old 08-23-2005, 04:46 PM
97Bird's Avatar
97Bird 97Bird is offline
Before replacing the starter be sure the connections are clean and tight on the starter. It just might save you the cost of a new starter
Old 08-23-2005, 09:12 PM
I checked all of the connections and they appeared to be tight...still had the same problem. I replaced the starter and all seems well. Thanks for the replies and ideas to help get me going again!
