Old 08-22-2005, 06:14 PM
EagleFURY97's Avatar
EagleFURY97 EagleFURY97 is offline
Wiring Glow Gauges NEED HELP
Hey i just got some glow gauges off of ebay for the ac panel and my dash for my 97 talon. it says to hook them up to the power source that is wired to the ac panel/dash gauges. when i took everything apart i couldnt find the correct wires. please help me find them
Old 08-22-2005, 06:39 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Wiring Glow Gauges NEED HELP
There should be some wires plugged into your factory gauge pannel. Take them off and hook them up to your new one.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 08-22-2005, 07:08 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Or just find any red (+) wire (make sure you test it first), and then just ground to the chasis. Even quicker, wire to cig lighter.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-22-2005, 07:29 PM
Re: Re: Wiring Glow Gauges NEED HELP
would the gauges light up when i turn on my driving lights using the cig lighter???
Old 08-22-2005, 07:48 PM
david-b's Avatar
Dave is THAT guy
Anytime the car/electrical is on, the gauges will turn on.
I've got mine wired to the light control switch. So if you turn on the lights, it turns on the gauegs. People also wire it to the dimmer switch. So it;s only on when the lights are on, and adjustable then too
75 Monte Carlo
Old 08-22-2005, 10:05 PM
Re: Re: Re: Wiring Glow Gauges NEED HELP
yeah i just got back from wiring the ac gauges and it works great. the best part is that my cig lighter light was burnt out so i just used the wires from the light to power it. one more q....what do u think the easiest way to wire up the dash gauges would b? since i have the cig lighter full
Old 08-22-2005, 10:26 PM
david-b's Avatar
Dave is THAT guy
Good job. You can add those to the cig too. It takes alot to overload the fuse. I got all my inside neons hooked up to it, and used to have my underbodies too, until I decided to rewire the whole car. Took some load off. Still have my pillar pod hooked up with the inside lights up. Dont worry about overloading it.
75 Monte Carlo
