Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-22-2005, 03:38 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Car making tapping noise
Okay... I know that ussually when your car starts making a ticking noise/tapping it is deffinatly time to change the oil. But the problem is that I changed my oil not to long ago and just checked it and it is fine but when I am at a stop my car taps real loud. I'm not sure if it taps all the time or just when it is idleing. But when I come to a stop my oil pressure drops all the way down to the low mark pretty fast. At first I thought it could be the oil pump because it normally happens when I first start my car. So I figured the oil was thining out as my car warmed up making it easier to pump, but the other day, after sitting in the drive through, at McDonalds I noticed that even after my car has been running for 10-15 minutes it still taps when I am idleing. My brother, who works at a garage, said my oil sending unit may be going bad. Anyone have a clue to why my car is tapping when it idles?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-22-2005, 04:45 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Re: Car making tapping noise
Sounds like your having a common case of lifter tick. Not a big deal, just annoying really. Being that your oil pressure is lowering, ( I am guessing your going by the stock guage, which isn't all that accurate) it makes the situation worse since there is a slight starvation of oil there to begin with.
The fix for this is to purchase 3rd revision lifters. You should be able to get them for 150 bucks or so.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 08-22-2005, 06:11 PM
cbell77 cbell77 is offline
I heard somewhere that if you put thicker oil in next change it can help reduce lifter tick. Also I had a ticking noise in my car not to long ago I thought it was lifter tick it just turned out to be a bad belt.
1966 mustang for sale asking $7900 call 757-766-3702
Old 08-22-2005, 07:02 PM
NateS's Avatar
Re: Re: Car making tapping noise
I just got back from Advanced Auto Parts, figured I might as well go ask, and the guy there told me to buy a bottle of oil thickener(always trying to get you to buy something) and put it in next time I go to put oil in my car. It was only 7 bucks so I'll give it a try. Thank you everyone for the help, it's much appreciated and alot cheaper than taking it to the garage haha.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-22-2005, 07:58 PM
NateS's Avatar
Re: Re: Re: Car making tapping noise
I found this website while researching lifter tick and thought I would share it with the rest of you. http://www.team3s.com/FAQliftertick.htm
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
