Old 08-22-2005, 10:59 AM
stlysmack stlysmack is offline
Send a message via AIM to stlysmack Send a message via Yahoo to stlysmack
Talking stalling
Hi, I have a '94 chevy Lumnia Van 3.1,The van starts up and runs good for about 15-20 minutes then it will stall. If I try to start it up again it starts and idles util I try to put it in drive then it stalls. If I let it sit for an hour or so it willstart up and I can drive it, but then the whole thing starts all over again. Anyone have any ideas what could be wrong.
Old 10-19-2005, 01:24 PM
meuhus meuhus is offline
Re: stalling
could be an ignition control mod
or crank sensor going bad
i have a lumina car so i don't know exactly
how your motor is configured
on my car the icm is on the front bottom of engine block
between starter and exhaust manifold
crank sensor is in the back of the block in the middle
near top of the oil pan
both of these can be tested at autozone
if you get them out
becareful taking out crank sensor
they some times break
Old 10-19-2005, 01:26 PM
maxwedge maxwedge is offline
A990 racer
Re: stalling
Will it rertart with a spray of carb cleaner into the intake, this will at least eliminate no spark problems.
Old 10-19-2005, 01:39 PM
Re: Re: stalling
my lumina died when i spraid carb cleaner down its throught
Old 10-19-2005, 02:49 PM
NeonKnight NeonKnight is offline
Send a message via AIM to NeonKnight
Re: stalling
it is your ICM, once your car heats up it starts acting up. mine did the same exact thing. if it was the TPS you would see that its cracked and it would throw a code. also if it was the CPS it would do it not only when warm, but cold also.
pull out your Ignition control module. i got one from Autozone for $108 after tax, lifetime warranty. car has never ran better.
