Old 08-22-2005, 04:58 AM
oldchevy oldchevy is offline
91 4.3L oil pressure sending unit.
Simple, but now i am not sure. I have done everything on my truck excpet replace the oil pressure sending unit. I bought a new sender and now I can't find where it goes. Does it stick out the back of the throttle body behind the distributor?? Is that it?
My oil pressue is almost always 50-60PSI and only drops to 30 after warm up at idle. Is that normal? If so, would it be the sender that is inacurate? I don't remember a time when the PSI was any different.
If its behind the throttle body, any suggestion on easy removal and install? Do I have to remove the actual distributor or just the cap?
1991 C1500, 4.3L 160,000 2WD
