Old 08-21-2005, 10:56 PM
thelawgiver thelawgiver is offline
'98 Blazer fuel pump problem
I have a '98 Chevy Blazer and it wouldn't start last week, so I replaced the fuel filter and it ran for three days. It was parked on an incline(fuel tank on bottom end). I took it out of gear so that it was level and it started. I filled the tank and the next day it wouldn't start. I replaced the fuel pump and it still will not start. I was told to recheck my connections so I did. I was told to check the pressure regulator and there was no pressure. I even went so far as to buy another fuel pump and hook it up outside of the fuel tank to try to hear it when I turned the key and heard or saw nothing. I have checked the fuses and relay in the fusebox and they seem to be good. Does anyone have an idea what the problem could be?
Old 08-21-2005, 11:27 PM
chigger23 chigger23 is offline
Re: '98 Blazer fuel pump problem
Hey dont take this the wrong way, but maybe the problem is your too cheap to take it to the dealer.
Old 08-22-2005, 12:18 AM
Yeah, those fuel pumps are real cheap at @350 . What way am I supposed to take it when you make a smart-ellic comment?
Old 08-22-2005, 12:20 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: '98 Blazer fuel pump problem
Don't worry, chigger is just a loser for posting that crap and if he keeps on doing it he will get kicked quickly off of these forums and IP banned.
Swap the relays and see if that works.
Other than that, you have a broken wire, or a bad ignition switch.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-22-2005, 12:23 AM
Re: Re: Re: '98 Blazer fuel pump problem
Thank you. It must be a broken wire or ign. switch, I swapped the relay.
Old 08-22-2005, 12:24 AM
Is there more than one relay? If so, where?
Old 08-22-2005, 12:31 AM
BlazerLT's Avatar
AF -Advisor
You can usually swap in the AC relay to check.
Sounds like a wiring issue more than anything or your sending unit may be bad.
