Old 05-05-2002, 01:56 PM
SFF900 SFF900 is offline
problem starting gsr swap
I just got done dropping a b18c1 into my civic, when i try to start it the starter cranks but nothing happens, the starter is working right, I am using brand new plugs and wires, I double and triple checked the ignition wires with my helms manual they are all connected and in the right place, the spark plugs are sparking, I double checked all the fuel injector wires they are all right, I am stuck, anyone else have any ideas on what to check or why it isnt starting? Thanks
Old 05-06-2002, 07:06 PM
j.fuggi's Avatar
j.fuggi j.fuggi is offline
check what error codes you're getting.
» Supercharged 2006 Honda Civic Si Coupe
» Info | Teaser Video | Dyno Video | Dyno Graph
Old 05-07-2002, 02:31 AM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
first off and im not trying to insult you but do you have the right ecu for the engine and are all of the plugs in the harness plugged in and are all of your fuses ok? one more thing, is the fuel pump working? whenever you turn the key to on can you hear the lines pressurize? thats all i can think of for now.
Old 05-07-2002, 03:23 PM
its ok im not insulted, but common sense would tell you I wouldnt have gotten this far in a swap plus the auto-manual conversion if i didnt have all that stuff checked already, the fuel pump works (i can hear the line pressurize) i just check the pgmfi relay for the fuel pump and injectors, im gonna go figure out what codes its throwing tonight
Problem starting latorawilson Impala | Impala SS 8 04-29-2011 03:14 PM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
94' k1500 starting/electrical problem k150094 C/K 0 08-21-2009 10:47 PM
