Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-21-2005, 09:07 PM
crxnoidea? crxnoidea? is offline
crx engine wiring NIGHTMARE!
i need help so bad..... i just bought a 90 crx 1.6 si i got it very cheap but the thing was the interior was gutted and the wirning harness was torn off the old owner was going to yank the motor. so i started hooking up the harness and i got the FI hooked up the alt hooked up and a few misc sensors and things. what i am lost in though is i can not find any wires to go to the starter and there are a bunch of plugs in the harness that i can not find anything to hook them too they just hang there. plus there is a plug coming off the bottom of the distributor that nothing from the harness fits. the engine runs if i can get it hooked up but i am so lost... plus can anyone throw an idea to just bypass using the harness for the starter anyone know how i can just rewire it on my own to a toggle or something like that? any ideas pics or wiring diagrams would be the biggest help
Old 08-21-2005, 11:02 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: crx engine wiring NIGHTMARE!
you are using the original harness that he supposedly yanked out. if it is uncut, then, all clips will bolt up only to specific sensors with the exception of the map and tps which are exchangable. the tps should be near the iacv, if you cant tell. been over 5 years since ive touched anything EF related. posting a pix with all sensors and wiring laid out and ill tell you where they all go.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-22-2005, 07:35 PM
the starter is the main thing i am worried about at the moment i can not figure out how it is suppost to tie into the harness but any pics would be awesome
Old 08-22-2005, 07:55 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
It should just be 1 single red wire and the ground that hooks up to the starter.
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-27-2005, 03:59 PM
thanks yall i finally got the engine all hooked back up now i am under the dash messing with it should have it up and running soon
Old 12-04-2005, 01:15 AM
VTEC2NRR VTEC2NRR is offline
.......WE CAN START BY WIRE COLORS/OF ONES NOT CONNECTED
