Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 08-21-2005, 09:00 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
intercooler
can the intercooler make my engine overheat? my dad thinks it mihgt be sumthin with that. and is the intercooler on a 13BT turboII intercooler air or air/water cooled? and once again, what is the part right beside the intercooler? it has a hose coming off of it and is bolted to the UIMill take pics of it wheni get a chance
Old 08-21-2005, 11:58 PM
NuTbAgSaN's Avatar
NuTbAgSaN NuTbAgSaN is offline
Send a message via Yahoo to NuTbAgSaN
thats a air to air o__O as for the rest i dont have a tII so im not too sure.
Old 08-22-2005, 04:01 AM
FDTT FDTT is offline
Re: intercooler
Your intercooler will not cause you to overheat. It will actualy keep the temps while drivng down a bit.
The peice on the drivers side (the IC exit pipe) goes to the throttlebody elbow. That elbow connects to the TB, then to a spacer, then to the UIM.
Dont drive faster than your angels can fly
Old 08-23-2005, 08:17 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: intercooler
get a front mount :P
or V
RX-7 TII
Old 08-23-2005, 08:25 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: Re: intercooler
or V
You go front mount and you WILL experience some problems if your coolant system is not up to the task.
1988 10th AE Edition TII
More mods then you have.
Old 08-24-2005, 06:52 PM
drftk1d's Avatar
Re: intercooler
i agree, i was joking
RX-7 TII
Old 08-25-2005, 02:35 AM
Re: intercooler
A V-mount can be worse than a front moutn if not done properly.
For the system to work to its fullest you need to have a vented hood to aloow air to pass through the IC and out the hood. Alot of cars have this setup, but they do not properly do it. They simpley have a vented hood and a V mount. In this case you have alot fo heat soak in the IC and woudl benifit better from a front moutn setup.
The way to fixx this is to build a containment box around the ic and have it seal around the hood vent. This sheild it from heat and directs air flow through the setup. Same thing can apply to the rad.
So if you go V mount it requires ALOT of work and fabrication.
Old 08-27-2005, 08:39 PM
NuTbAgSaN's Avatar
must be why we dont see too many on fc`s
Old 08-28-2005, 03:01 PM
Re: intercooler
same thing applies to FD's. I see all these people running around with there pre-made V mount setup. When in actual fact they wodul have been better off running a front mount because there is no ductiong and no exit for the flow of air though the IC so it just cavitates int he engien bay and heat soakes. :P
Old 09-05-2005, 12:53 PM
drftk1d's Avatar
Re: intercooler
i seen alot on fcs
RX-7 TII
