Go Back   Automotive Forums Car Chat > Ford > Probe
Old 08-21-2005, 09:55 PM
keepers15 keepers15 is offline
Unhappy timing 93 probe v6
hello need help in setting timing on my 93 probe v6 2.5 timing is 9to11 degrees but when distributor is turned timing stays the same does the computor control the timing or can it be set any help??
Old 10-03-2006, 09:56 PM
vonage003 vonage003 is offline
Re: timing 93 probe v6
you have to go to the data link control by the battery you need to jump the "gnd" pin to the "TEN" pin and that will put the car in base timing then that enables you to change the inital base timing.....if you dont understand how to do this feel free to email me or send me a message
Old 10-05-2006, 09:28 PM
annajajay@sbcgloba annajajay@sbcgloba is offline
i dont understand
Old 10-05-2006, 09:30 PM
did u time the probe
Old 10-06-2006, 04:05 PM
CrossGT6's Avatar
CrossGT6 CrossGT6 is offline
Send a message via AIM to CrossGT6 Send a message via MSN to CrossGT6 Send a message via Yahoo to CrossGT6
Pop the hood and look above your battery. There is a black small box that says Diagnotics.
When you open it the top inside of the cap has a pin diagram jump the TEN and either GRD with a paper clip and then turn the car on and adjusst timing.
Now remember the car controls ignition timing so your really only going to help the car a little the car will always correct it to what it wants once the car is running normally (aka without ten and grd jumped).
Don't forget to remove the paper clip with the car off when your done setting the timing.
I stayed up one night playing poker with Tarot cards. I got a full house and 4 people died.
"Bub's are you an unethical quack?" - Homestar Runner
"Aww, now my heads not taped to the TV." - Strong Bad
I see you have the ring and I see that your Schwartz is as big as mine. -Dark Helmet
"The Claw decides who will go and who will stay."
"This is ludicris..." -Woody Toy Story
